Fuse F35 keeps blowing on Focus XR5 Turbo / RS mk2
oemdeniedperformance
Common DTC associated with this fault are as follows:
P0076 - Intake valve control circuit low
P0079 - Exhaust valve control circuit low
P0102 – MAF sensor circuit low input
P0245 – Tubo/Super Charger wastegate solenoid low
P0458 – EVAP System purge control valve circuit low
Common symptoms associated with this fault:
Limited boost - only 1/4 up the gauge in all gears
Higher than normal fuel consumption
